Steps for Wrangler
FirstJeep
USA
I have a 2000 Wrangler with a 2” body lift and 31” tires and I was wondering if y’all could suggest some inexpensive steps that I could use in getting in the Jeep. I’m not as young as I used to be unfortunately😬. I have installed grab bars but still need a little help. Any help would be greatly appreciated.
Reactions: RussTJ
I used to have these. Worked fine. I kept banging them in the rocks, so I removed them, but they worked well for a step.
Reactions: RussTJ
I have these Carr steps that I welded the brackets to a flat steel plate. I then drilled holes thru the plate and then drilled and tapped the underside of my Rock Sliders. They are held on by 2 3/8" bolts and lock washers. When I hit the trail its remove 2 bolts each side and good to go.
