It’s so oily back at the rear of my engine this must have smething to do with the problem I’m having
Thank you! S131/134 are these areas I should look at too ?Splice 184 is on the left rear side of engine. Splice 185 is near the rear of the valve cover.
View attachment 142168View attachment 142169
I would. Given the chain of events, dry engine compartment everything was fine. Power steering pump soaks engine compartment, now you have problems. If the engine compartment didn’t get soaked with oil I would be looking solely at what all 4 codes had in common, which is g105 and the PCM. Since that’s not the case, check all splices and connections in the two wiring schematics I posted.Thank you! S131/134 are these areas I should look at too ?
You can use the electrical cleaner inside those plugs?Get yourself a few cans of electrical contact cleaner and disconnect/remove the connections and liberally clean everything with the cleaner. Allow to dry and reassemble. See the wiring gutter at the rear of your valve cover. Unsnap the lid and inspect the wiring insulation for chafing or bare wires.
Yes, that’s what it’s designed for.You can use the electrical cleaner inside those plugs?
YesCan you use electrical contact cleaner on the pcm plugs or no?
Okay so the splice are wrapped up wires right? So I need a voltmeter to check these wires to know if they’re the culprit to the 02 problem I’m having?Usually a splice can not be verified bad with a visual inspection since the spliced wires are internal to the splice. The way to check a splice is to meter it from both ends and wiggle it around to see what the meter does.
s184 location?
S185 is under that little cap?
S131 is under the same cap above the valve cover?
And then s134 is behind the coolant temp sensor? Do I need to remove those plastic covers to access these points?
That connector appears to be for the air conditioner compressor clutch.Also what’s this sensor located right below the power steering pump right above the lower rad hose? It looks like it’s associated with the 02sensor
