Good choice!!
Now I can’t wait for the 0-60 video. Again.
Good choice!!
If stock 190hp is 20 seconds (mainly due to poor shift gap between 50-60), supercharged ~260hp is 10s, do I have guesses for 500hp LS?
4 wheel burn out!!!!Depends if you go with the 6L or 4L transmission.
I’ll guess sub 7 seconds easy.
either way, 4 high launch!
10s still-5 sec burnout with a 5 sec travel timeIf stock 190hp is 20 seconds (mainly due to poor shift gap between 50-60), supercharged ~260hp is 10s, do I have guesses for 500hp LS?
They quoted my rubicrawler at 6-8 and it was half that.It looks like the longest lead time item will be the Atlas at 6-8 weeks until it ships. So I think I should get that ordered ASAP.
@mrblaine do you have any advice on configuring the Atlas?
Well, getting into reverse quickly is a huge life saver. A manual valve body and differnt shift pattern with a matched gate can save your rig/life if the occasion was to show it’s self.The 4L can be adapted to use a manual valve body (not beneficial for most of where I'll be going)
That would be my concern.The final concern is that if the 6L80e is too wide, a front driver's side drop driveshaft will have a lot of issues getting around it. This is an issue with high uptravel builds that also have a high pinion axle and something I dealt with my 42RLE.
2wd, and you can get away with the smaller tranmissions. Add 4wd, big tires, beadlocks, big axles, and a transfer case and it creates a division. My .02
Most of the guys I wheel with that have v8 swapped are using the winters shifter from WOD. Then set it up for the bottom most position to be manual (3) and next up to be auto (4). Some of them cut off the lockout between 4 and 3 for a quick slam up to reverse. This is a pic of one done with the Rad Designs tap shift kit.I'm looking at doing PRND21 (6 position shifter). PRND will function as expected. 2 will be manual (TUTD). 1 will be 2nd gear start for when you don't want the trans to shift right away.
@Fouledplugs is a huge WOD fan, they make some awesome stuff.Most of the guys I wheel with that have v8 swapped are using the winters shifter from WOD. Then set it up for the bottom most position to be manual (3) and next up to be auto (4). Some of them cut off the lockout between 4 and 3 for a quick slam up to reverse. This is a pic of one done with the Rad Designs tap shift kit.
They're really nice and knowledgeable folks. I know they're running into supply issues right now, but give them a call and see what the lead time is.I'll have to ask them if they can do the same thing but with an extra position.
