Mrblaine, you mentioned heat control for the swap. You talking hood vents kinda stuff? Radiator stuff? Whatchutakinbout Willis?
The reason we are doing a stroker on this one is to avoid the cost of the V8 swap. That and to try and sneak it past the smog stations. I'm being promised over 300hp and closer to 325 with a high level of reliability. We'll know shortly if that is true.Makes sense, but to me, the added complexity of a complete motor swap isn't appealing. If I had the money to turn the keys over to Blaine for a V8 swap Id feel would be done right, then Id do it. But, I didn't buy this Jeep for that purpose. Most Ill do is a stroker or basic rebuild with boost.
What's so hard for me, when it comes to engine swaps especially with V8s is that you can just buy a plethora of vehicles with the V8 already in them. Or you can go with something newer and a V6 with more than enough power and torque to put a smile on your face.Makes sense, but to me, the added complexity of a complete motor swap isn't appealing. If I had the money to turn the keys over to Blaine for a V8 swap Id feel would be done right, then Id do it. But, I didn't buy this Jeep for that purpose. Most Ill do is a stroker or basic rebuild with boost.
Under the tub.Mrblaine, you mentioned heat control for the swap. You talking hood vents kinda stuff? Radiator stuff? Whatchutakinbout Willis?
It is going in a build with the basic goal of just getting it back to stock feeling performance. Yet one more nail I put in the 4.0 coffin.Thats a stout build from the sounds of it.
The Savvy rig ran a 350hp stroker that had to be gone through after every race. At the time, there were no upgrade parts readily available so the 42RLE was just gone through with sound rebuilding practices by a great shop. It never had a single issue in all of the races it was put through even with that much HP in front of it.What transmission is going behind the stroker? I'm asking because I've had a new Golen stroker motor sitting in a crate in the garage for a while now. I've been hesitant to install it out of concern that it will not be kind to the 42RLE transmission. However, I thought I read somewhere that the Savvy/Currie KOH LJ originally ran a stroker and 42RLE, but later went to a V8.
Discussions with my builder about folks that want an 87 octane build are along the lines of "why bother?".
Now there are better parts for the 42 so if you do find a weakness, it can be remedied other than the stupid OD ratio.
Ever buy premium at an old two pump gas station on a twisty mountain two lane while on a wheeling trip?Whats the problem with running premium fuel?
I don't have a smart phone but I know there's gotta be an app for that.Ever buy premium at an old two pump gas station on a twisty mountain two lane while on a wheeling trip?
It's funny how alot of people who have never built a stroker jeep tell you that they will only run well on premium fuel. If the engine is built correctly ( zero deck with the correct camshaft),a stroked 4.0 can run great on 87 octane. Mine was 9.5 to 1 compression and it was fine. If you do the old 4.0 pistons on 258 rods, it will ping on 87. The pistons end up in the hole about .045 inch, and another .040 gasket makes for shitty quench. Nobody builds them that way anymore. There are more a few good options for pistons now to fix this without spending a fortune.
Another thing about strokers people run their mouth about is they need to be tuned to run properly. Not true. If you are looking for that last 3 percent, yup, a tune will help. I have ran a couple with 24 lb injectors and a 62 mm throttle body and they run fine. It's the old school way to ' trick' the engine into thinking it's still a 4.0 and not a 4.6 or 4.7.
Also,as blaine said, a 42 re will hold up fine to a 300 hp stroker. A fresh rebuild with a couple upgrades does wonders for them. People want to build a hot engine and put a wore out 200000 mile trans behind it and are surprised it doesnt make it. Dumbasses.
People need to go back to doing shit and learn instead of cocking off about stuff they have never done . Might be time to get off the internet and go build something.
