Got the finalized version installed today. It centered up the axle shafts perfectly so I’m happy with the initial install. Hope to go wheeling on Wednesday if my body allows it.
Updated feedback as you go along is appreciatedGot the finalized version installed today. It centered up the axle shafts perfectly so I’m happy with the initial install. Hope to go wheeling on Wednesday if my body allows it.
So far they have been great. I only have about 30 miles or so With them on the pavement. Seems nice and tight. No weird or unwanted effects with them at all so far. I also got out for a quick trail ride with them but nothing extreme. Again can’t even tell they are installed. So only a bit of time will tell if they last longer than the normal ball joints do for me.Updated feedback as you go along is appreciated
Nope.Pure laziness here but do you need a special steering knuckle or some other conversion to run these on your basic dana 30?
You charge what people will pay.From what I can see on their website, these things look pretty simple in terms of design (unless I am missing something). So that begs the question, why are they so expensive?
Thanks Jerry.I would say that's accurate. It seems that most of the people I talk to who are running 35s on the Spicer ball joints are getting a few years out of them or more, then why bother to solve a problem that doesn't exist. Especially when the "solution" could be over $500.
My first thought seeing a setup like that was "that's an odd way to run a spherical ball" and I guess I'm not the only one.In other words, this is the worst possible direction to run a spherical bearing under load.
But if it's fixing a problem for the guys running huge tires, then go for it. Seems like a mighty expensive fix though.
These are for 37's.I'm still not clear on what these BJs are supposed to fix. Isn't yoke stretch the unsolvable problem with huge tires on stock axles? If we agree that 35s are the reasonable limit to stock axles and that 35s aren't huge, what are these for?
No, they are "for" those who didn't build a big enough front axle for their tire size.These are for 37's.
Just for reference. Toyota IFS guys been running them like this for a long time. I had these in my Taco and jumped it and beat the ever loving piss out of iit with fox suspension on fire roads, never had an issue. lasted like 5 years before rust got to it. Newer ones used stainless balls. Mind you it has WAAAAAY bigger moment arm than Dana 44 C's.My first thought seeing a setup like that was "that's an odd way to run a spherical ball" and I guess I'm not the only one.
