Any good choices for small or mini footprint amps? I have a Pioneer avic600 (I think it is 25w per channel) deck and 6 rockford fosgate speakers. It sounds good but a small 2 or 4 channel amp might be helpful.
Thanks!
Thanks!
I like that setup. They are proud of it though. LOLthis is what ive been using for a while now.
https://rockfordfosgate.com/products/details/t400x4ad/its tiny compared to the last amp i had.View attachment 217253
There are a few options for them - just make sure you get the one that doesn't have the pre-wired harness... I got mine for a smoking deal (open box) and it works fantastic. I did run a dedicated wire to the glove box for 12V+ (it doesn't need an incredibly large one).Will these alpine micro amps work with my Pioneer deck?
Did you put it in the glove box or behind it (by the fuse block)?There are a few options for them - just make sure you get the one that doesn't have the pre-wired harness... I got mine for a smoking deal (open box) and it works fantastic. I did run a dedicated wire to the glove box for 12V+ (it doesn't need an incredibly large one).
See comment #4 above for a photo - I used some 3/4" plywood and a few pieces of scrap angle iron to mount it under the steering column. Makes for a nice short run for the RCA cables and I tied the speaker wires back into the factory harness...Did you put it in the glove box or behind it (by the fuse block)?
i had the older JX400/4D couple years back.I found a local guy who seem sto know about off road sound. He recommends a JL audio amp due to it's durability in harsh conditions.
This is what he is suggesting:
https://www.crutchfield.com/S-BovvcHc8bN7/p_13698361/JL-Audio-JD400-4.html
He has it on hand brand new for $220 What do you guys think?
edit, it is 10 x 7.5 inches
