SOLD 2004 TJ Rubicon | Light Khaki, 5.13 gears, auto, hard top, A/C
nk24
307 ► 602
Phoenix
Price
16500
Phoenix
The time has come to find a new home for my TJ Rubicon. It is an original Arizona vehicle and has been lovingly cared for in the 3+ years that I have owned it. We tackled some great trails, saw some amazing sights, and even won Ride of the Month! I recently bought an LJ and it is time for someone else to enjoy this great vehicle.
This TJ has been in Arizona since new. The frame is pristine and rust free.
Clean, Arizona title in my name
Price: $16,500
(Price includes both hard top and soft top. We can work a deal with just one or the other, or no top as well.)
Specs:
2004 Jeep Wrangler TJ Rubicon 4.0L in Light Khaki Metallic
138,400 miles
4.0L engine
4-speed 42RLE automatic transmission
NP241J Rubicon transfer case with 4:1 low range
5.13 gears (Revolution)
Dana 44 front axle with factory locker
Dana 44 rear axle with factory locker
33" Goodyear Duratrac tires (285/75/R16)
16" factory Rubicon wheels
Cold A/C and hot heat
Cruise control
Tilt
Factory hard top (black)
Factory soft top (khaki with tinted windows)
Factory full-size hard doors
Factory rear seat
Factory 19 gallon gas tank
Factory Rubicon rocker guards
Factory leather wrapped steering wheel
Factory khaki interior (dash, console, seats, carpet)
Factory rear view mirror with auto-dimming, compass, and thermometer
** Original build sheet available upon request **
Extras:
3.5" Rubicon Express short arm suspension lift
Rubicon Express front track bar, rear track bar, lower control arms
Currie Currectlync steering
Rancho RS5000x shocks
Sway bar disconnects
Savvy transfer case cable shifter
Spidertrax wheel spacers
Speedohealer (speedometer correction after gear change)
Alpine stereo head unit
Polk DB522 5.25" speakers (dash and rear sound bar)
6" subwoofer in console
Skid Row JP-0019 engine and transmission skid plate
KC fog lights
Tinted rear windows
6" fender flares
Fumoto oil drain valve (makes oil changes a breeze)
LED interior lighting (overhead and footwells)
LED backlighting in instrument cluster, HVAC controls, and rocker switches
WeatherTech all-weather rubber floor mats
GraBars entry and exit handles
Independent locker switches (can turn on front without turning on rear)
Heavy duty battery terminals
Daystar dash top tray
New items:
New radiator (Mopar, 2019)
New radiator hoses (Gates, 2019)
New water pump (Mopar, 2019)
New thermostat (Stant 195°, 2019)
New fan clutch (Hayden, 2019)
New O2 sensors (NTK, 2019)
New fuel management valve (Mopar, part of emissions system, 2018)
New spark plugs (Autolite iridium, 2019)
New rear hard top window seal
New door seals
New rear wheel bearings and seals
New ignition actuator and ignition switch (Dorman)
New Delrin door hinge bushings
New gas cap (Mopar)
New rear window struts
The good:
Engine runs and idles perfectly
Transfer case shifts perfectly from 2wd to 4Hi and 4Lo with Savvy cable shifter
Transmission shifts smoothly
Hard top is great in the summer heat and the winter chill
Averages around 15-16 MPG
Geared well for 33" tires both on the trail or on the highway; can be a daily driver
AZ emissions good through April 2022
AZ registration is inexpensive ($90 for two years)
Has been in Arizona since new; zero issues with rust
The not-so-good:
Tires have decent tread but are older and should be replaced
Valve cover is leaking a small amount of oil (I have a new Fel-Pro gasket that will be included)
Other:
I have a Garvin Wilderness roof rack that was originally installed on this TJ. If you're interested in the rack, I can definitely put it back on.
More photos available upon request.
That's a winner . Good post too, very transparent.
Reactions: nk24
Forgot the engine bay photos:
Clean lifted rubicon at a number less than some ask for a beat model. I can't say I'm too surprised.
@nk24 Do you have your eyes on a particular LJ or are you just in the market?
I picked one up about a month ago here locally after searching for about 18 months.
Reactions: Alex01
