What are you trying to pull here?Final shock measurements are this:
Impressive. How long did it take on the RMS? I heard they are a pain.Rear main seal, new oil pump, and pan gasket are in. Hoping to get some time today to install new O2 sensors and the new catalytic converters.
I had the entire rear and exhaust out, so the RMS was easy. Otherwise it is challenging, but not overly difficult.Impressive. How long did it take on the RMS? I heard they are a pain.
More persnickety than anything else. The rough part is getting the upper half installed without nicking it. Then you have a dozen'ish bolts for the girdle and 20 or so for the oil pan that all have to be torqued.I had the entire rear and exhaust out, so the RMS was easy. Otherwise it is challenging, but not overly difficult.
This is very, very true! Anyone installing a RMS should make sure to use the supplied plastic tab, to ensure the top seal doesn't get knicked. I've learned this one the hard way and had to make a trip to the part store for a second seal kit. Also, care has to be taken to ensure both the upper and lower halves are installed correctly, with the small lip facing forward.The rough part is getting the upper half installed without nicking it.
Crap. As it stand now, I'm sitting at $530 in the Rock Auto cart. I have a new Mopar water pump, so the new Mopar radiator is the major culprit. The current radiator was just replaced, and seems to be solid, so I may forgo that for now.You're this far into it, I'd say replace it, along with a new water pump/thermostat/idler/tensioner pullies.
What's $530 or whatever it takes when it comes to peace of mind?Crap. As it stand now, I'm sitting at $530 in the Rock Auto cart. I have a new Mopar water pump, so the new Mopar radiator is the major culprit. The current radiator was just replaced, and seems to be solid, so I may forgo that for now.
I'm trying to sort out whether the replacement Mopar automatic radiator uses the original factory fittings. IIRC, the original radiator used quick disconnects. However, mine was replaced recently with the barbed style. I imagine I could swap them back, if I can find the correct fitting.What's $530 or whatever it takes when it comes to peace of mind?
I have the orignal in mine and a replacement on the shelf for my auto. I'll check both tonight.I'm trying to sort out whether the replacement Mopar automatic radiator uses the original factory fittings. IIRC, the original radiator used quick disconnects. However, mine was replaced recently with the barbed style. I imagine I could swap them back, if I can find the correct fitting.
Code: 169182077150679566 |
Thank You for Being a RockAuto Customer! Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. |
Radiators are easy to replace. Water pumps and timing chains not so easy. That does not set of my MAW meter too hard. I'd skip the rad if it's in good shape.
They said share the code and ever little bit helps right.
this thing is going to be brand new. Got a killer deal too!
Hang in there, Dude. It’s just work. You got this!The more I work on this, the further behind I get.
- Replacing the RMS and oil pump resulted in a need to replace the timing chain (due to 1/2+ chain deflection)
- Planning to replace the timing chain resulted in ordering an entire new cooling system (due to the discovery of a slight water pump and radiator leak)
- Ordering a new cooling system led to the order of all the under hood A/C parts (because, being this far in, access to the compressor is easy and I see two small A/C leaks)
At some point I'd like to get to the installation of all the armor, some of which requires painting it body color. This crap is either going to kill an old man, or help keep him younger. Sometimes I don't know which of the two is winning!
