Here's a list of the parts used for the front end and what I learned:
- Savvy CE-9100SA Control Arms
- Moog DS1430 (1) Drag Link
- Moog DS1312 (1) ZJ Tie Rod
- Moog ES2079S (2) ZJ Tie Rod Terminal
- Moog ES3096L (2) ZJ Tie Rod End
- Monroe SC2928 Steering Damper
- H&R 52107 1" Lift Springs
- Omix-ADA 18280.25 Jounce Bumper
- Moog K160039 Front Spring Insulator
- StreetRays SR-JEEPTJ-FRLIFTCUP1 Billet 1" Spacer
- Currie CE-9120TJS Front Track Bar
- Alloy USA 11200 Dana 30 5/16 HD Cover
- Lube Locker LLR-D030 Dana 30 Gasket
- SwayLLOC SL-TJLV
- Pro Comp 69 Wheel (15x8 with 3.75" BS)
- Mickey Thompson ATZ P3 Tire 31x10.50R15
- Yukon YA WU-07 Small Hub Kit
The Savvy lower control arms had to be adjusted almost all the way in, set to the stock arm length, to work with the small lift. Once this was done, all the parts here played well together, with a couple small exceptions.
The combination of the Alloy USA 5/16 cover and the Currie track bar interfered with each other, when cycling the suspension. This resulted in a hard stop, requiring 2" bumpstop extensions, if left as is. A significant amount of trimming of the Currie track bar gusset, along with minor grinding on the Alloy cover, allowed the suspension to go to full bump, with zero interference. This meant zero (0) bump stop was required. As a note, I had the track bar in and out at least a dozen times while clearancing everything. Only after I was done making sure the Currie track bar would work did I drill the required 5/8" frame side mount hole, and 1/2" axle side mount.
My other top three things I learned:
1. This site continues to be an invaluable resource for those of us that are willing to learn.
@Chris does an amazing job of ensuring content is updated and discoverable. Now, whenever I search anything, I preface my google search with "wranglertjforum". This helps ensure I get worthwhile results at the top of my search list first.
2. The experts here are exactly that, experts, and are willing to help. We can help them help us, if we make it simple and clear what we're asking for, with pictures, and are specific with describing where we are in the process. Bottom line, don't assume they can, or want to, read your mind!
3. Cycling the suspension really does show the interference points. In my case I had two areas that required grinding and cutting, along with one stupid positioning I did with the tie rod terminal adjuster bolts. Taking the time to make sure everything works resulted in resolving some issues that could have damaged parts later, and certainly limited useful suspension travel.
All that said, a special thanks to
@Chris,
@jjvw , and, especially
@mrblaine . Their contributions here help all of us put together a better rig, if we're willing to listen and do a little work.
