Kevin E TJ Enthusiast Lifetime Supporting Member Joined Nov 1, 2015 Messages 850 Location Wharton, TX Aug 12, 2017 #1 Replacing front wheel hubs and noticed my new bolts which are Crown and not Mopar are a bit longer. Is this going to cause any problems? Should I add a washer to back them out at all?
Rob5589 Certified video trained differential rebuilder Supporting Member Joined Aug 29, 2016 Messages 6,691 Location W Sacramento, Kalifornia Aug 12, 2017 #2 Too close for me. Is there some reason you cannot use the original bolts?
OP Kevin E TJ Enthusiast Lifetime Supporting Member Joined Nov 1, 2015 Messages 850 Location Wharton, TX Aug 12, 2017 #3 The heads we're rounded off from P.O. not using the 12 point socket
OP Kevin E TJ Enthusiast Lifetime Supporting Member Joined Nov 1, 2015 Messages 850 Location Wharton, TX Aug 12, 2017 #4 It looks like they tried and gave up or something. The other hub wasn't touched so those came out and went back in no problem
OP Kevin E TJ Enthusiast Lifetime Supporting Member Joined Nov 1, 2015 Messages 850 Location Wharton, TX Aug 12, 2017 #5 Found OME bolts so ordered them. I don't really like it myself.
Rob5589 Certified video trained differential rebuilder Supporting Member Joined Aug 29, 2016 Messages 6,691 Location W Sacramento, Kalifornia Aug 12, 2017 #6 Kevin E said: Found OME bolts so ordered them. I don't really like it myself. Click to expand... :emoji_thumbsup:Good idea
Ahoragi TJ Addict Joined Mar 25, 2016 Messages 1,272 Aug 12, 2017 #7 I don't see a problem with running those bolts. They are the wrong length but will not cause any issues.
