They come that way from the factory.Was this an attempt at Cho Low lol all tires no jeepFuck there is a speed hump ahead I better take another route
Looked way too fat? You sound like my wife. "Do these tires make my Jeep look fat?"My 99 had 31 x 10.5 x 15 tires on stock rims when I bought it. They weren't aggressive tread but they rubbed on tight turns. To me, they looked way too fat.
Wonder why they are on this jeep with smaller than stock tires. Guess it may have had larger tires at one point. HmmmmThat be it, if necessary.
I'll agree that looks nice? That's 31x? On a stock lift? Also which tire? I'm sure you've said but I've been through too many threads to recall. Also, how much is your speedo off? Hers is currently off and 4mph with the 235s vs 30" it came factory with. Maybe there's an easy fix for that?
Technically a 31. Goodyear Wrangler MT/R LT245/75R16 (30.5"x9.6") that come on Rubicons, so the speedo was accurate.I'll agree that looks nice? That's 31x? On a stock lift? Also which tire? I'm sure you've said but I've been through too many threads to recall. Also, how much is your speedo off? Hers is currently off and 4mph with the 235s vs 30" it came factory with. Maybe there's an easy fix for that?
I don't know. I'm on a lot of construction sites, and I can hit some mean piles of 5/8 minus gravel-Lol.215 to 235/75R/15 or 29/9.5 is the right size proportionately with no lift, thats 2 sizes up from what you have.
Factory had a 30" option but 30" is not 30"
29s look the same as 31,s on a 2" lift without the lift except they have about an inch less diff clearance for off roading. Your TJ looks like it aint going rock climbing anytime soon
Keep it "Proportionate" looking! 29s or max 30,s is my opinion unless you want big tires and then a a lift.![]()
Boogieman, the tread and size of your tires is exactly what I am thinking I would like to shoot for. Good height and profile. What brand are they? Plus, I like the color!
Post #25 above.Boogieman, the tread and size of your tires is exactly what I am thinking I would like to shoot for. Good height and profile. What brand are they? Plus, I like the color!
I personally really like the stock look, so went with 30 x 9.5s. I also think that 31's without a lift look a little too fat within the wheel well. When I was deciding between 30' and 31's, I went to some websites, like Cars.com and just checked out what I thought looked best. Even had to call a few dealers and ask, "What size tire is on that '03 Jeep"
Looks good to me.I personally really like the stock look, so went with 30 x 9.5s. I also think that 31's without a lift look a little too fat within the wheel well. When I was deciding between 30' and 31's, I went to some websites, like Cars.com and just checked out what I thought looked best. Even had to call a few dealers and ask, "What size tire is on that '03 Jeep"
Post #25 above.![]()
You have a 2.5L. Your options are limited.Ditto. I have that same wheel and tire combo right now. Enjoying it so far.
p.s. You need the correct speedo gear to fix yours. $20-30 and 5 minutes of your time.
My speedo is spot on with the GPS on 235,s they must have change the speedo drive in the factory when the 30" option was chosen?I'll agree that looks nice? That's 31x? On a stock lift? Also which tire? I'm sure you've said but I've been through too many threads to recall. Also, how much is your speedo off? Hers is currently off and 4mph with the 235s vs 30" it came factory with. Maybe there's an easy fix for that?
ProportionI personally really like the stock look, so went with 30 x 9.5s. I also think that 31's without a lift look a little too fat within the wheel well. When I was deciding between 30' and 31's, I went to some websites, like Cars.com and just checked out what I thought looked best. Even had to call a few dealers and ask, "What size tire is on that '03 Jeep"
Us mall crawlers dont do scraping anything! We traverse our speed humps at 45 degrees on and 45 degrees opposite lock offIt depends how you use them offroad. My aftermarket trans/oil pan skid was scraped all to hell.
