Head over to the TJ Resources sub-forum, download your factory manual and check out section 24-1. It has a description of the clutch operation, diagnosis, and replacement procedures. If your clutch just took a shit then it's pretty straight forward - just remove the belt, swap out the clutch & call it a day. Check the manual out & then let us know if there's anything in there that isn't covered by your situation.
Edit - are you a pretty handy DIYer? Not trying to call you out or anything, just trying to figure out where you're at on stuff & how much help you need.
Edit #2 - Just a thought if your TJ is a daily driver - I haven't ever done it myself, but according to the diagram in your FSM on page 7-31 it looks like you might be able to just go get a non-AC serpentine belt in the meantime & skip the AC compressor. That could buy you some time to figure it out at your leisure without having to take it to a shop & at least make it driveable if you don't need AC. Just a thought.
Alright, if you can do that you can definitely change an AC clutch. When you get into changing a compressor it gets a little more complicated with having to evac & recharge the AC system, but the clutch itself doesn't involve any of that. Check out your manual & post up any questions you have.Nice, thank you. I might consider that to buy some time, since it’s no longer AC weather here anyway.
It’s not quite a daily driver. I work from home and we have a second car. I can take my time on this.
And no, I have almost no mechanical background. This is a new hobby and I am keen to do what I can and learn as I go. Most advanced thing I’ve done is swap springs and re-align, or drop the tank and fix my fuel ‘burp’ problem.
I don't see a picture of your problem, but there's a clutch and bearing. In my years of experience normally if the clutch is worn slap out the compressor is right behind it. Lots of times compressor locks up and clutch disintegrates, the bearing can go out, you'll hear noise all time not just when a/ C on. Anyway I'd replace compressor and clutch,bearing asm ,or bypass compressor with non AC belt. Good luck !
If you have a way to recover the 134a, I would just replace the compressor. A new compressor is less than 150.00 from rockauto.
The compressor bearing and seal assembly will be the next to go bad after swapping the clutch assembly.
IF the compressor bearing goes this will lock up compressor, break the serpentine belt, possibly damage the radiator and cooling fan/clutch assembly.
Agree with the others on bypassing the compressor with a non A/C belt or not drive the Jeep until you can afford to replace the compressor.
So the way it works is that the compressor clutch is magnetic. When the AC control knob is in a non-AC position the clutch is disengaged which allows the pulley to freewheel around the compressor without spinning the internals. When its in this condition you can look at the face of the compressor while the engine is running and the inner part of the pulley should be stationary.
When the engine is running and you turn the knob to an AC position (one with a snowflake) the magnetic clutch engages and the outer pulley connects itself to the inner part of the pulley. Now you're spinning the compressor and using your compressor.
What happens when you just turn the HVAC off? Does it still make the squealing noise?
If it were me at this point & I would remove the clutch & see if the compressor shaft still turns smoothly.
Although this is only my own experience, my A/C clutch bearing failed several years ago. I got a puller and removed the clutch and pressed out the bearing. Took it to Napa and had it matched, pressed in the new one and it's been fine since. All my drive belt bearings, tensioner and idler have been replaced before. I know the older clutches are different but if it's similar I'd start with that. Cost wise it is far less than anything dealing with the compressor and the bearings are around $25.
Mine was different but for free most auto parts stores rent complete A/C clutch puller and adjustable clutch tools that lock like this wrench. OTC 4537 looks like it might work.
Edit: funny how that wrench is just sitting on the clutch with the pins in the wrong direction in the illustration with the socket wrench just resting on it, "here are the tools just randomly placed on the clutch, go figure it out."
