Sorry. I should have waited till I finished the project with pics. The ram ball is a newer mount system that holds stuff tightly.
I'm glad you cleared that up. I Googled ram ball and came up with this. This mount does look better though. 🤫
Reactions: Don Ashcraft
It is specifically for my Garmin Overlander. I gave up on my iPad running Gaia. I was missing turns by 100’ pretty often. Some trails are hard to back up that far.
Nice work! that looks so slick, I might shamelessly copy this :cool:
Haha, I will help you along:
1)1/4-20 gr8 bolt 1" long
1)1/4-20 flange nut
1)1/4-20 coupling nut
1)1/4-20 X 1" ram ball
I had thought to make a plate to span the two screws that hold the bezel on, but a 1/4" slot was already there. The only mod I did was to trim the plastic back enough to fit the flange nut (which is a nice feature but a washer and standard nut would work too).
some blue loctite if you are prone to mistakes or red if you are like
https://www.amazon.com/dp/B00AHCUNG2/?tag=wranglerorg-20
This may be stronger, but you will have to trim the stud most likely:
https://www.amazon.com/dp/B082YF5QHN/?tag=wranglerorg-20
I made mine to hold one item but these things are super configurable:
https://www.amazon.com/dp/B082YFP113/?tag=wranglerorg-20
put a magnet on the face??
https://www.amazon.com/dp/B004O8LF26/?tag=wranglerorg-20
Different lengths arms, etc.
https://www.amazon.com/dp/B005KWPJ04/?tag=wranglerorg-20
Been having problems with the fuel pump on my 97 TJ for a couple of weeks so yesterday I pulled the gas tank and today I cleaned up the skid plate and painted it and cleaned the gas tank and while I was in there I converted it from a 15 gal to a 19 gal tank… now where is that Amazon truck!
Good luck getting that bigazz nut back on,you have to hit it with a dead blow hammer
Reactions: 97JadeTJ
