Whew that's close!!!!!
On a more serious note, the tires are the main reason I haven't done much wheeling with this thing as yet. I need some M/Ts - I do NOT like getting stuck.That may be as far as you can get with those tires. You just need some bigger all weather radials because everyone should know that SIZE MATTERS.
Should I air down even lower than normal for such high altitudes? Don't want to pop a tire!M/Ts, Mountain Tires!!!
When I first started wheelin I was using Metsker's maps.That's what I used when I drove a truck for a living
I found a color matched set of factory flares for about $50 to fix ours.
What handles are those?I cut up the trim on our '03 prjoct to mount these new grab handles. I like them.View attachment 287481View attachment 287482
Yea, it’s small enough that I’m going to do a little research and tackle it myself. It’s been there for 6 years, but it’s time to try and fix it right. They are the factory Sahara flares and are perfect aside from that spotI found a color matched set of factory flares for about $50 to fix ours.
What's the little electronic dingus on the driver's side? OBDII display of some kind?I cut up the trim on our '03 prjoct to mount these new grab handles. I like them.View attachment 287481View attachment 287482
I am available for adoption, I also live on a real mountain and you can come visit anytime you like
I got them on eBay for $40.What handles are those?
It's an inexpensive TPMS module. It has a small solar panel on the backside, but I also added the micro USB cord for power/charging while the ignition is on...What's the little electronic dingus on the driver's side? OBDII display of some kind?
