Sorry for the long post, but please feel free to jump to problem statement directly.
Background:
I have been having this weird issue on my 97 TJ 4.0L (since last 2 years I have owned it now at 130k) which is a weekend warrior. It will have this burnt obnoxious smell coming from engine bay through the vents which will happen only after being restarted after a 30-40 min break like after a short non-highway city trip of 5 miles or less (like driving back after a short lunch/dinner/errand). Never used Heat/AC and often times it will just dissipate away after 5 more minutes of driving - No CEL or anything. I have taken it to the mechanic but couldn’t replicate it and he suspects it is the coolant or engine oil (I have a RMS leak) burning off of the hot exhaust. Luckily I never had this issue with any off-roading or highway trips of 1hr or more each way- but then I may have never restarted within 30 min or let the engine cool off.
Issue:/Problem Statement:
Yesterday night the same burnt smell came up after dinner and went away in like 5 minutes and I proceeded with kids for some drive through Christmas lights - 1st gear 5mph driving with clutch/break 20 minutes . On the way back home the smell came back again but kept on increasing and ended up of with high RPMs & complete loss of power. The RPMs kept going up but no power and the vehicle won’t buzz in any gear. Luckily I was within 1/2 mile from home and after several cranking and cool off I was able to crawl it home on 4low only with lot of persuasion.
Came home and used the OBD scanner and got P0340. Then read through the forums here and got the following codes with ignition key on/off 3 times - not sure if it is relevant.
12
54
55
Just got the CPS & OPDA from Napa, will start replacing stuff. What do you guys suggest? Please advise, totally clueless here.
Background:
12
54
55
