Hi everyone. I took my 99TJ in for an inspection of the transmission and the transfer case. Shifting into 2nd and 3rd isn’t smooth and 4HI is loud at speed.
They found the transfer case to be leaking between the two halves (topped off fluid) and the transmission to be making internal noise that they suspect is bearings.
It has the stock ax15 and transfer case. 4 inch lift. 33s
They quoted $5k+ to fix both, which I think means find used replacements that are in better shape than mine and swap them.
They also said I could drive it for a while longer and see how it goes. They both work and may be fine for a while, they said.
I’m new to jeeps so just wondering about experiences with issues like these.
Would your recommendations be any different?
