I have a mostly stock LJ. Bought from original owner who hardly drove it / never used 4wd.
Recently tested out preload on the Dana 30. I don’t have the “most” accurate tools but preload read at 12. That’s basically new. iirc spec is 12-14 inch lbs
Is that spec possible with a 18 year old vehicle or were gears/something in diff changed out?
It has 3.73s in it so if it was changed it was changed with stock gears.
PO “can’t remember” if anything in front diff was changed.
