Having fuel tank dropped on my 99 wrangler to replace skid plate and straps. Your opinion on whether I should replace fuel pump now even though it is working fine?
Having fuel tank dropped on my 99 wrangler to replace skid plate and straps. Your opinion on whether I should replace fuel pump now even though it is working fine?do it whenever-wherever you want.
I've though about making one of those, I didn't know you could buy them. Can you cut the opening with the tank and lines still in place?
I would say yes as 24 years is a long time
I just ordered a pressure regulator. My pressure goes from 45 running to 35 immediately after key off and then zero inside of 20 minutes. Takes either three ignition on/off cycles to reprime or a long crank.
I want a new skid. Can't afford $692 right now. I think I have a replacement Bosch pump for the assembly... probably going to drop the tank this weekend and at least do the regulator.
Rokmon is $274 for steel. 3/16.
Any idea of the weight?
I have a steel one I could make you a deal on.
What symptom is causing you to replace just the FPR?Meanwhile dropping the tank this weekend to at least do the regulator...
