Yes I talked to you about it,I still haven’t heard back from Gobi about the body lift ,customer service sucks,lol
I’ve ran the Gobi Stealth rack on my TJ with and without a 1” body lift without any issues if that helps.Yes I talked to you about it,I still haven’t heard back from Gobi about the body lift ,customer service sucks,lol
The brackets are different aren’t they?I’ve ran the Gobi Stealth rack on my TJ with and without a 1” body lift without any issues if that helps.
I got mine used from a TJ without a body lift. Slapped it on mine and later on added a 1” body lift without any fitment issues.The brackets are different aren’t they?
The bracket that attaches to the frame/tub has room for movement to compensate for the body lift that I recall.Wow if the body went up and the rack is attached to the frame? Do you still have it-thanks
Oh I get it,if I was closer I would buy it,getting ready to retire and doing some overlandingThe bracket that attaches to the frame/tub has room for movement to compensate for the body lift that I recall.
I took mine off and posted it for $800 +shipping. I’m located in Medford, Oregon.
Oh I wouldn’t think about shipping itThe bracket that attaches to the frame/tub has room for movement to compensate for the body lift that I recall.
The front attaches to the window frame and the rear bracket has slots and can accommodate a 1” body lift.
The upper portion is one piece and is oversized so it’s hard to pack and ship.
I want to sell mine but it is for an LJ and located in Ca.
I’m planning on being in New England for the fall colors this fall. That drive would be an adventure in a TJ. I plan on flying into Boston and renting a car. Looking forward to seeing your part of the country.If you drive the LJ to New England I would be interested in the rack
Yep,I really like the Gobi,towing the Jeep ,it would be nice to have one to store stuff as you tow,the only thing I heard was that on a soft top they kinda shake around Offroad,because the top support above the side windows can’t be usedGarvin makes a decent rack, too. With and without support hardware. Depends on what you're planning on putting up top. Plus, they're made in the USA.
