Hey y'all, was wondering if I could get some help narrowing down what might be happening with the jeep lately
First the specs
2000 Wrangler Sport
4.0L I6
5-speed manual
164k miles
So 4-5 days when coming home from a job I started running into some issues. I was at a stop light, at a complete stop in neutral and when the light turned green and I go to put it into 1st I get blocked out of the gear. No grinding or anything, it just blocks me from moving the shifter into gear, much like it will if you're going above 5-10 mph and you try to shift down into 1st to keep you from over revving the engine by accident. It took maybe 20-30 seconds of struggling with it and it finally let me in.
At this time I'm almost completely out of gas, so I go to the nearest gas station. While I'm coasting through the parking lot I have it in 1st with the clutch pedal pushed in and I noticed that the transmission is trying to catch, pulling me forward a bit. Only briefly and not much, but noticeably.
I get filled up, make my way home, and when I pulled into my parking spot I noticed a noise coming from the engine area. It was a high pitched, squealing chirpy kind of sound. Its not constant, but comes on and off every few seconds and only when the clutch pedal is pushed in.
The first issue with the blocked gear only happened that initial time, the engine catching while the pedal was pushed in has happened a few times in the past few days, but the noise has been happening constantly when going in and out of 1st gear.
I've been trying to do some research and it sounds like maybe one of the bearings is going out? I try to do basic maintenance on my own, but I'm worried this is going to be out of my capability to fix myself and would like to have a basic idea of whats happening before going to a mechanic and getting taken for a ride.
Thanks in advance
First the specs
2000 Wrangler Sport
4.0L I6
5-speed manual
164k miles
Thanks in advance
