Hi Folks-
When I purchased my 2005 Rubiharra it already had a 2.5 inch OME lift/suspension system on it. I have since installed a set of KO2 33's.
It drives just fine, but as others have said in previous threads, my current lift is not enough to utilize the full articulation of the suspension system with 33's.
I would ask if someone could post a link to a good and easy to install body lift to provide the correct level of minimum lift. Is the correct recommended lift height still 1" - 1.25"? Any other considerations? The posts I have read have led me to belive that I do not need a SYE kit- is this assumption correct?
Thanks for your recommendations.
