Hey everyone,
PO had put an RE long arm kit on the TJ and predictably all of the bushings and joints are shot and it rides quite terribly. After doing a lot of research it seems like long arms aren't really the way to go and Currie/Savvy short and mid arm kits are where it's at. Unfortunately PO had chopped the existing mounts to install the RE kit. I've heard of some approved weld on brackets but that route seems extremely expensive to chop off all the long arm brackets and then weld short/mid arm brackets on (I'm not a welder).
I feel like this is an unpopular question but what are the upgrade options at this point? I've researched replacing the bushings + Currie joints but it seems like the RE design just blows and I'll be replacing the bushings again soon.
I found a Metalcloak direct bolt in upgrade kit (not sure if I can post links) but product ID 7149. The downside is that it doesn't come with the rear uppers (ID 7093). The rear uppers use a significantly larger bushing so the existing brackets on the axle would need to be cut out and MC brackets welded in anyway
All of the MC kit would come to just under $2k. I can chop the existing brackets off but I'd have to get someone to weld the new MC brackets on. Is this my best "upgrade" option where I wouldn't have to replace bushings that frequently and restore ride quality? Any help is appreciated!
