Florida The move to Florida is on!
I just pictured Jerry in this situation - now I'm desperately clawing my eyes out...
Are you just referring to steep pitches? It surprised me how all the new construction in Oklahoma is 10/12+ but front range Colorado was all 4/12. I think in those areas it mostly came down to cost. Oklahomans don't have to spend $50k in permits and water/sewer tap fees so they have it to spend on extra lumber and labor because it makes the house more impressive looking.
Specific examples - the architectural guidelines where we're building sets a minimum of 9/12, and where we almost built in CO in 2019 it took a lot of arguing with our designer just to bump it up to 6.
Yep, the steep roofs that present a huge dam for the wind to hit during a 'cane. Makes no sense to me. This old house was built in 1963 and has a 4/12 roof. "Architectural guidelines" like you cite are stupid and ridiculous. Is it a stupid county ordinance or is there CCRs and an HOA involved?
I was happy to help after Katrina
HOA. It's not nearly as restrictive as some I've been in or heard about, but that's a very common requirement. I'm not sure a 4/12 roof has been built here since the early 70s except on the most entry of entry level houses.
There's probably a crossover point with whether shallow or steep roofs are advantageous. A steeper shingle will absorb less impact energy from a falling hail stone, for example, and I think with wind, a more vertical shingle will better resist being lifted up and stripped off or moisture intrusion, while the larger cross section of a steeper roof is more at risk to the actual structure being removed from the house. So it might make more sense here since we don't have hurricanes.
Reactions: Zorba
I am of the opinion that CCR/HOA stupidity is largely coming from building departments - perhaps they won't allow a subdivision without them in many instances? At least I haven't heard of any building development in the last 40 years or so that doesn't have them. Yet another end run by a gov't agency.
Reactions: 5632
I'm sure most are, and mine may have been copied from one that had that influence. Mine is in a rural county that doesn't even do permits though. It's pretty much the wild west.
There was apparently QUITE the fight with the Brevard county board a number of years ago. There were various ordinances on the books - including RV parking - that the people here got tired of. The board was told "You are NOT an HOA, if we wanted HOA rules, we would have bought a house in such a development. BUTT OUT!" Surprisingly, they did.
And with FL’s humidity, 40s is pretty miserable. That’s coming from a guy who grew up where it’s routinely -20F, and the coldest temp I‘ve experienced is -54F! Some of my most uncomfortable outdoor experiences were just above freezing, with high humidity.
Exactly! I was more miserable and cold marching across the flight line during the winter at night at Keesler AFB in humid Mississippi than I ever was when stationed at Grand Forks AFB in North Dakota where it reached -53 but with much lower humidity.
Reactions: Blondie70
So... When you're in the desert and people all about the heat, the reply is already, "yeah, but it's a dry heat."
I've never heard anyone say the same about cold...
"How do you deal with this cold air?
"It's not too bad... It's a dry cold" lol
Reactions: Blondie70 and pc1p
It's easier to avoid that kind of nonsense living in an unincorporated area of a county with only 48k people, with the nearest town having a population of 270. 😏
We *have* an HOA, but it's run by residents (not a management company), and once the house is built its unlikely you'll cross paths with them again as long as you keep your lawn mowed and don't start a salvage business. I can build any fence I want other than galvanized chain link (black chain link is fine) and not in front of the house, and I cam build any size shop I want as long as I use materials consistent with the house and don't put it within 20 feet of the lot line. It's a far cry from the ones we had in CO where I had to submit applications for approval to build a fence in my backyard or paint my garage doors a different color.
Reactions: TJ4Jim and Zorba
High humidity matters for your comfort whether hot or cold. If you've never heard anyone say it, here you go:
It's not about the cold, it's about the humidity! :D
Truth. 40 in Oklahoma is about as comfortable as 15 in Colorado.
St. Augustine is a really cool place!
Yep my pops lives next to the alligator farm on the island,we will end up here too,north enough and next to the ocean it stays a lot cooler than southern Florida,but if you leave your car out it will rust quickly,the salt is in the air and sits on the car when you wake up!
Reactions: Jerry Bransford
