hey guys i have a 2000 jeep tj 6 in lift it is all over the road putting new adj control arms on front what should i set my lower arms be set at upper also i get a reading of -6 degree on top of ball joint flat spot should caster be plus or minus
I know this gets said a lot around here but what should said is that you want as much caster as you can dial in without inducing driveline vibrations. It does little good to have a perfect driveline angle if you TJ drives like a shopping cart.Pinion angle is more important than caster.
No punctuation keys on your keypad?hey guys i have a 2000 jeep tj 6 in lift it is all over the road putting new adj control arms on front what should i set my lower arms be set at upper also i get a reading of -6 degree on top of ball joint flat spot should caster be plus or minus
You want positive caster. The lower ball joints should be forward of the upper ball joints. Think of the forks on a bicycle. I Agee with the other post getting the pinion angle correct with as much caster as you can get.hey guys i have a 2000 jeep tj 6 in lift it is all over the road putting new adj control arms on front what should i set my lower arms be set at upper also i get a reading of -6 degree on top of ball joint flat spot should caster be plus or minus
