If I am driving or just sitting my key keeps popping out of the ignition? The key is still required to start or turn off the vehicle. Any ideas please? Thanks
Me too, since 2006 and next thing is "key lock button" locks the new key in. I fixed that with small NAPA vinyl sticker used as a "tactile reminder" over lock button and using old slip-n-slide key.Happens to me but haven't fixed it yet because it doesn't bother me enough yet lol
I just installed this. Get to keep the factory key, very nice.The lock cylinder is worn out. Get one of these and install it. The problem will be solved. FWIW, these are easy to do and allows you to re-key the new ignition lock to your existing key.
https://www.amazon.com/gp/product/B07D8BKR5M/?tag=wranglerorg-20
Here's a real Ass-Kicker in 93' I worked for Warnock #4 Dealer in country. PLL Leasing wanted a Jeep they were the largest leasing co, in the U.S.You're a stage past when I replaced the one in my 99. I hopped in and realized the key felt funny in my hand as I started it up. Looked down and I'd just started the TJ with the key for my Silverado. Not only were the keys nowhere near the same cut, the cross section of the key body was so different that the Silverado key won't even slide into a healthy TJ cylinder.
It's easy to rekey them, too. I think I had to borrow maybe 1 or two wafers from the old cylinder to make the new one match, the rest was just changing the order they were in.
