I recently purchased some used 15x8 wheel vintiques steelies that were previously used on a TJ. I did a test fit on one of my axles and noticed I will need hub centric rings. The problem is I can not find the size I need online. The TJ hubs are 71.50mm and the wheels have a 79.375mm opening. The closest I found were 71.50 to 78mm. Just to avoid another question I did try to reach out to the previous owner with no reply thus far. Thanks for any help.
Edit: I just did some quick conversion math. If I went with the 71.50mm to 78mm rings it’s only .05” smaller than the wheel opening. Would that work or do they need to be exact?
