Any recommendations for an endoscope to check the condition of my body mount internal nuts/bolts? Have seen an Amazon version recommended here that has a 5 mm diameter probe but another version has a little better reviews?? (a ton of complaints about the App required on 5 mm version) but probe diameter is 7.9 mm. For those of you that have used the 5 mm version was it barely small enough to get in smaller openings and maneuver inside around corners etc. (again, trying to see the top of as many body mount bolts as possible) or do you think the slightly larger 7.9 mm will work?
Any other brands that have worked well?
Any info/recs appreciated.
5 mm recommended version - https://www.amazon.com/gp/product/B01MYTHWK4/?tag=wranglerorg-20
7.9 mm version I am looking at - https://www.amazon.com/dp/B0928Q3T42/?tag=wranglerorg-20
