I ordered both to compare, wasn't sure which I wanted. Heres a breakdown difference.
All and all, the UCF is comparable to the Savvy, IF you want it tucked. Interestingly, the Savvy uses T joint welds vs UCF's Square or Corner joint welds. I have heard that T joints are stronger, but with the force being mostly from below during a "encounter", the pressure distribution would be better on the T joint.
To address questions of weight difference, the Savvy uses Steel brackets for the body mounts which are bolted to the Aluminum skid. The UCF is a single welded Aluminum skid. Yes, the Savvy has 12 lbs of steel added to it.
Savvy 3/16" Thick 6061-T6 Aluminum GTS | UCF 3/16" Thick 6061-T6 Aluminum GTS |
Price - $530 (all parts needed included) | Price - $510 (with needed parts - $571)
(fuel tank straps - $38, misc nuts and bolts, - $23) |
Weight - 32 1/2 lb's | Weight - 19 1/2 lb's |
Height - (set at 1" BodyBlock build) Lower Lip - 5" / Upper Lip - 11" | Height - Lower Lip - 5 1/4" / Upper Lip - 11 1/4" |
