I can't see the video clearly but at least you've got it lined up.
There may be a bigger hole above the bolt hole in flex plate that you can use to pull converter forward.
Between the flex plate ring gear and the transmission housing there should be enough room to get a thin piece of steel or screwdriver to help pull the torque converter forward as well. It shouldn't take much if you can lift the torque converter near bottom center.
