2003 4.0 auto 4inch lift
New to me bought of the auction with 125000 miles
Starts no issues will drive no problem but will stall after about 3 miles and won’t go in gear engine won’t rev and will feel like there’s only 3 cylinders working out of 6. If you shut it down and give it 2 min it’ll start and rev again but if you attempt to drive it’ll do same thing basically longer you wait longer it’ll let you drive after. So far replaced spark plugs, replaced crank sensor, cleaned throttle body and sensor, tested fuel pressure and it’s at 40 even when it stalls, checked temperature on catalytic converters and it’s good.
If you leave it idle it never stalls no issue. Another thing it has transmission leak from the core somewhere but level is normal and it shifts no problem.
Any suggestions?
Any suggestions?
