1st we need to separate the word weave and the term unnecessary movements.
the motions Blaine describes are unnecessary movements. it's a crutch used to waste time until material has been deposited.
weaving is done for a reason other than personal motion preference, maybe the project requires a very large weld, or it's gapped, or you're spreading the root.
the sprockets i run require a large weld deposit, they are responsible for up to a 10k load capacity. i'm not permitted to run multiple passes, though that's how it should be done to be correct in this instance. (pic below of the robotic weave with flux wire). that weld is about 1/2" on a 7k hub and 1 would have to run very hot and extremely fast and super accurate to even come close to as uniform as this comes out. i can't do it by hand this neatly. you can see a pattern but it doesn't have pronounced highs and lows the flux runs pretty flat. if run in a straight line the flux wire is capable of a very smooth finish if welded flat or semi vertical (less then 75*).
spreading the root is what we do in vertical down corners, and i would consider it a weave, it's dictated by the need to root well into both pieces. a secondary benefit from this action is it can help us shed wire and avoid an over flowing deposit from heaving or dumping out on us.
gaps are their own issue and can take different techniques to fill different gaps, but the ability to run a slow steady straight line is still key, needing the crutch or unnecessary motion will work directly against you in this instance.
this type of welding often requires bursts and not full on run n gun. i start at my open ends, a few tacks on each piece and meet in the middle. then i start from 1 side, establish a root and proceed across using the bridge i made to help hang my deposit and into the other piece and root. let that go totally dark, then repeat. (** dark **, your weld should only glow for 3-4s, if you can count 5-6 mississippi and still glowing, you're "to hot" and probably havin a hard time right now).
so the description in the quote above is fairly accurate, you need a pause for cooling so you can use that previous deposit as a bridge. if you're struggling with burnout and cannot get across, turn the power down just a tad and try that. if you cannot turn the power down move faster.
this ain't a great pic i even left a bead or 2 of spatter i should have taken off, shame on me. but i hope you can see the uniform machine weave.
