This question comes up often, so I figured it's time for a FAQ on the matter.
The later model 4.0 engine (2000 and later) is what is known as a DIS (Distributorless Ignition System) which is far fussier about what spark plugs it likes to run well on. A DIS ignition system also fires the spark plugs twice as often which means a conventional copper-core spark plug only lasts half as long in this type of engine. All 4.0L engines that are 2000 and newer have the DIS ignition system. 1999 and older 4.0L engines aren't nearly as fussy so long as they are the right model plug. 2000 and newer 4.0L engines won't run well for long on single-tipped Platinum plugs, even though some catalogs show them as an acceptable plug. So do avoid any platinum plug that only has platinum on the center electrode.
I always recommend dual-tipped Platinum or Iridium spark plugs which will perform well for at least 100K miles. Iridium tipped plugs will last significantly longer than even the 100K miles dual-tipped platinum plugs will.
Good dual-tipped platinum plugs include the
Autolite APP985 and Champion 7412 at
https://www.summitracing.com/parts/cpn-7412
A great iridium tipped plug for the 4.0 engine would be the
Autolite XP985. A technical trainer at I know at Autolite checked his iridium plugs at 165K miles with his company's electron scanning microscope and they showed no wear yet.
Such plugs last so long that it's a good idea to smear a tiny dab of
copper-based antiseize onto their threads before screwing them into the head. Make sure no antiseize gets onto the electrodes (tip).
So while conventional plugs are what the factory installs and they are the cheapest, that doesn't mean they are the best choice for replacement spark plugs.
NOTE: 30,000 miles is the recommended spark plug service interval for conventional (non-platinum/non-iridium) spark plugs due to 2000 and newer 4.0 engines having a waste spark ignition system.
