Will a body lift on my Stock TJ give me enough room to put 32" x 11.5 tires on without rubbing? And if so, how much of a body lift would I need?
The search feature is your friend.
You really don't want a body lift taller than 1.25 or so. But to answer your question. 3 inch body lift will clear a 32 inch tire. I would rather you use budget boost spacers or another method to lift your jeep but in the end its your call
Thanks for the input, I wanna make the smartest decision.
You will be so much happier with a small body lift and a small budget boost. You can always go taller down the road with the budget boost. I personally hate any body lift over 1 inch or so.
If everyone did that, there wouldn't be any discussions for new people. With that thinking I could just Google everything. But thanks for the input
I'd really like to get 32's on my jeep if possible with lout a suspension lift, if possible.
You’re right on the money. Ignore the search Nazis. I deleted his post for him since it wasn’t contributing anything. A 1.25” body lift and some 1/2” spring spacers ought to do the trick.
Just a question..why 32? I know a few guys on here that have done builds based around a 31 inch tire and that is enough for 90 percent of jeep owners. Just my .02
Double check your current springs. If they are sagging, some of the suggestions above might not be enough. Most of above is based on a good stock spring.
Thats the kind of info I'm looking for. Can I still use my Stock shocks with the spring spacers. I just put new Bilstien 4600 series shocks on.
1” lift springs https://www.amazon.com/dp/B00C7M0NRO/?tag=wranglerorg-20
My vote Spring lift + Savvy body lift= 2.25” lift
A stock TJ suspension works fine with 31" tires. That size tire comes standard on a Rubicon TJ which comes with a stock suspension height. A 32" tire only protrudes 1/2" taller upward from the axle than a 31" tire does so a 1" to 1.25" body lift gives more than enough additional room to accommodate 32" tires.
The added 11.5" width of 32x11.50 tires will be fine when the tires are mounted on aftermarket wheels which have reduced backspacing which moves the tire outward and away from the suspension.
