What am I missing or misinterpreting from the chart at https://static.summitracing.com/global/images/chartsguides/m/mgr-f890633.pdf
For the later design Dana 35 like I am assuming the TJ uses it says its 26 spline pinion shaft is 1.376 and the Dana 44 pinion shaft diameter is 1.375, also a 26 spline design.
I had no idea they were that close and that it appears from that chart that the Dana 35 pinion shaft is .001 larger than the Dana 44's is. Something's not making sense to me.
