Those who are swapping an AR for SwayLoc, are you using your AR links or the supplied SwayLoc links? There was some discussion whether the heims were not good quality on those provided by SwayLoc.
That's certainly letting the tail wag the dog.
I was going to keep my antirock for the ends but someone offered me 300.00 and I sold it.
I'd hope JMT is moving the Antirock over to another Jeep of his own.
Bingo. The Rubicon or a future dedicated trail rig.
These are what replaced what came on the SwayLoc.And you want the better links for yours. Whichever they may be.
Where’s that damn tool Blaine made?!
Thank you @mrblaine for the phone call. I got it all together and greased up. Appreciate you taking some time out of your busy day to help.
@Moglocker. That's what I was about to do when my requested phone call from mrblaine took place. I was about to pry open a slot but wasn't sure. MrBlaine's other advice helped me see it all. Then it came together. Thanks!
All I can say is WOW. The ride is soo much more stable after running an AR on the loosest setting. I set the SwayLoc on the 2nd slot from the front, so biased stiffer. I am already screeching tires around corners just to see what it can do!
I know,it’s pretty great
So what was it that @mrblaine told you ? Can you share it
