Thanks,
Assuming, if done properly (unlikely I'm thinking), a longer line should be fitted when lifting or does a 2" lift normally 'get away' with stock length?
Not knowing what the PO did to your Jeep; couldn't hurt to keep an eye the brake lines while lowering the differential.
You don't want to stretch them tight during the spring removal.
