So, I'm a a point of decision. Originally I was going to put this entire unit into my 2002 and had purchased a flexplate and starter for the 2002. However, now it is going into the 2005 LJ and that uses a smaller diameter flexplate as well as a different crank pattern. The difference is major as the 2002 is 13.75" and the 2005 is 11.5" or so. The other issue is the 6R80 torque converter fits inside the larger early flexplate, and does not fit inside the later one. Thus my adapter plate would probably end up being twice as thick for the later flexplate. I would however be able to use that flexplate for the crank pickup. So, I need to make a decision whether to continue using the early flexplate and make a crank trigger wheel for the front of the engine, or the later smaller flexplate and deal with a thicker adapter plate?
