OP
Yes, dead on arrival. Financing an ~80,000 rig to beat up off-road for a niche market is a DOA business model.
The side-by-sides would be your current business.
Weight is a significant factor. A current RAM 3500 and similar trucks weigh in around 8,000 lbs, and once stuck you can easily double that to 16,000. A Tj comes in around 3,500 and has nowhere near the ass required to move that. Your Jeep couldn't even move a 3500 parked in a parking lot.
There is a tow service at a beach I frequent who pulls out the stuck 150/1500 and 250/2500 guys. This is what is used. Notice it weights quite a bit more that what is being recovered.
I'm not telling you to not start a business, just to think about things in a logical format, and go about it in a smart way. I'd rather see someone succeed than to be set up for failure from the start.
You're right. I will reconsider pursuing this as a business from the get-go.
However, I think the hobby part would be fun - and I'd make a little money too.
As far as weight, I could get around that depending on how I leverage myself versus the vehicle I'm pulling out. Yes, certain trucks may be out of my range. However, as far as momentum and leverage is concerned, I have no doubt I could jury rig a winch system which would do exactly what is needed. Especially if I include ballast tanks, anything could be moved.
Alternatively, I may end up fitting soft bumpers to the front or back end. I have seen them around town, and they do the job. I could push, where pulling is not an option. However, damage to the vehicle being pushed would need to be considered.
