P0888 code on a manual transmission
https://wranglerfix.com/
866 888 7710
Jeep Wrangler TJ (1997-2006) Replacement PCMs​
Rated 5.00 out of 5 based on 4customer ratings
(4 customer reviews)
$392.20 – $1,582.20
Dodge, Chryslers and Jeeps are no strangers to circuit board issues. Specifically the 2005-06 TJ PCM problem, which unfortunately without a recall, legal action, or support from the manufacturer has left many Jeep owners stranded.
That is until now!
Because the stock Jeep PCM’s cannot simply be rebuilt, this was not an easy fix for us. (Same exact issue with 06-07 SRT-8 Grand Cherokees that we also solved!) When the 05-06 TJ PCM fails, it’s virtually impossible to repair. I equate it to trying to put Humpty Dumpty back together again. I sent the OEM PCM to two major repair companies that came BACK with the same conclusion: DOA
Here’s what we did to solve the issue:
  • Purchased an 05 Wrangler
  • Purchased a working PCM ($2500.00 at the time)
  • Our techs identified a Chrysler OEM part that most closely mimics the 05-06 TJ’s and configured the hardware and software to come up with the only true Wrangler PCM Fix!
It’s important to mention that because of the software configuration, our PCM’s will not support tuners, superchargers or updates/flashes from the dealer. However, it will perform all functions of the OEM PCM and pass emissions in every state!
  • USA Proud
Reactions: Jerry Bransford
Hello Mark, i must not be using this interface correctly. I responded asking if you reprogram ecm…
Fs1 is stalling again and not responding to my request.
What does your fix cost? What does it include(warranty etc)?
It sounds as though FS1 has put you through enough down time and torment so there will be no charge for fixing your pcm. It will be done same day and on its way back to you. Your "lifetime" warranty is still with FS1 so hopefully you do not have any future issues.
Please send me a PM with tracking when you can.
All the best,
Mark Cantrell
All the best,
Mark Cantrell
Wow that’s an amazing offer. Ill pack it up tonight and mail tomorrow.
Thank you so much
Hey guys,
I replaced my PCM the other week. The emissions drivers were dead.
I have a 2006 Rubicon manual trans. The code I'm getting is P0888. As far as I can find this code is for a automatic trans.
Am I wrong? Is there a fix I can do before I scream and yell at a Sales people?
Hello Northvgorgiarider, did you ever get the po888 error code resolved? Mine is persistent. Thanks
