JKP
If that is from the shop, the problem is not your timing set, it is the OPDA gear and possibly the cam gear.Thanks guys. I feel confidentish lol in my skills but also don’t know if I have the time if things go wrong since this is my daily driver.
Is it normal for this to go bad at 140,000? Feels really early. Just want to make sure this is even the right route.
Does this make sense to you guys. “Checked cam/crank data. Shows they are off by 3 degrees. Removed cam Syncro cover and found that there is excessive play in Syncro. Removed distributer and found that drive gear has been worn down over time and there is excessive play in the timing chain. Can replace timing chain and condition will improve *but if distributor gear is worn too much, DTCs may set in the future*.”
OPDA gear wear is a know 05 and 06 issue. If the OPDA (passenger side of engine where the distributor used to be) is an LDI unit, it needs to be swapped out for a Crown or Dorman unit. The cam gear needs to be inspected for wear.
