How do you tighten / remove the radiator supports on the Savvy body lift?
ThomasFletch
Redlands, CA
Does anyone know how to tighten/remove the radiator supports on the Savvy 1.25 BL? I know that you have to take the headlight out to access the top bolt, but how do you grip it? I've tried pliers, wrenches, a vice grip, using a pry bar to try to hold it in place, all in vain. Or should I just cut them off and replace them with the extended JKS snubbers?
Why do you want to replace them? The jks ones typically have the feedback of being too stiff. I run the savvy ones with no issues. Possibly a belt wrench mat work to get them off/keep them from spinning.
Do what you are told! 😡
😄 I'm like wtf you guys replying to me for. Yes I did all these things. I currently don't have a problem with my body lift and was trying to help this dude who is obviously trying to remove this body lift for some reason.
I doubt putting anti seize on it will help him now...
Reactions: Moglocker and jjvw
Cool, I'll avoid the JKS ones then. Yeah, the Savvy ones are good, I was just trying to remove it because it was loose, and the rubber bushing thing was bad on the inside.
Pipe wrench
This is what I ended up doing, it worked.
I remember holding the puck in my hand using socket with extensions to tighten the bolt. Getting it tight was not a problem
Same here. That's all I had to do on mine.
I think I did this when I initially installed it, but it kind of rusted on there, I think.
