There’s your problem, Mike. Your torque converter has a bunch of cuts in it…
The transmission is out!
Now, I just need to tear the rest of the Jeep apart and rebuild it with all the auto parts. Easy peasy, lol.
I’ve also finished the rebuild of my tcase. That is sitting on a bench, ready to bolt up to the auto.
While there is no trans bolted up to the motor, that is the time to sneak the cooler lines behind the exhaust. You may have to loosen the manifold bolts and swing the head pipes over to the left a tad, but that beats doing it later and dropping the whole mess.
Thanks for the tip! I don’t suppose you have extra of the clamps that are supposed to locate the transmission lines, do you?
Disassembly continues…
Got the difficult harness out. It took me a while because I worked on it, got frustrated with the stiff, dirty connectors, and had to take a break. So I’d play with the dogs or watch some YouTube, then go back at it. Got everything out with out having a temper tantrum or breaking anything. That’s a win in my book!
Also, more proof that my Jeep has something weird going on in the front end… my upper intermediate steering shaft is off center in the hole through the fire wall.
I’m confused. What does the O2 sensor have to do with the block of plug? I can probably pick it out on mouser too, now that I know what the series of connector it is.
Nothing, two separate posts. You will pull the block off plug out of the one on the firewall to connect up the auto harness. I need the block off plug for the one I just converted to a manual since I sent mine to someone that needed it.
The O2 sensor thing is me poking fun at Jeep's nonsense for making the 04 a stand alone year for the sensors. We've had to move the connector shells around to do the swaps and it seems very odd to have to do that. If you're lucky, your new harness is an 04 as well. Ours have been an 04 harness for the 03 we were working on and then the 03 harness went into an 04. PITA.
What did you put in the OD off switch spot?Oh, and I gotta figure out my switches. I don’t have room in my center bezel for the O/D switch, plus I HATE having a single switch for two lockers. Gotta think on that one. Right now, I’m thinking to make something to hold the factory 4 switches (O/D, rear defrost, rear wiper, and bonus) then I’ll make some spots for Carling switches for lockers and rock lights. I’ll 3D print it out of ABS on my work machine.
Got some reportable progress this weekend. Got my old manual radiator out and built the support for the transmission cooler I'm installing. Like every project that I do where I haven't "been there" before, I have some clean up to do from rust. This time, its the mounting screws for the A/C condenser. There is like a little button with threads inside a rubber grommet that holds the condenser to the grill shell. Not sure where I'm going to get those to replace them, so I may "invent" something.
The V-bar was in decent shape. Welded on some 1.5 x 3/16 cold rolled flat stock I had kicking around. By now, this is old hat, but here is my cooler mount
After the parts cooled, the v-bar got a quick run through the sandblaster and a shot of some satin black paint. I also cleaned up the raw steel on my brake pedal assembly and painted that. Finally cleaned up my shop a little bit from all the disassembly. That part of the project is done. Next up is replacing my intake/exhaust gasket and changing my motor mounts. I have the MORE motor mounts that lift the engine 1". I am going back to brand new Mopar Motor mounts with an aluminum lift block. The Cooler should be installed early next week (after a couple parts arrive). The Grill and auto radiator will go in soon too. The "new" radiator needs a good cleaning...its packed full of mud!
Them be wellnuts. I have many, they can go out in the care package tomorrow with new flange head screws if it helps?Got some reportable progress this weekend. Got my old manual radiator out and built the support for the transmission cooler I'm installing. Like every project that I do where I haven't "been there" before, I have some clean up to do from rust. This time, its the mounting screws for the A/C condenser. There is like a little button with threads inside a rubber grommet that holds the condenser to the grill shell. Not sure where I'm going to get those to replace them, so I may "invent" something.
That would be wonderful. I just put a package of 10 of them in my cart, but if you have em, I'll buy em from you.
