What is the length of shock that should be used with the 4inch lift ( rockjock ce-9131 rear and ce-9132 front springs assuming I have it setup to utilize the full travel of the spring. I have the jeep completely torn down at the moment so modifying and outboarding can easily be done and would like to order shocks. I'm thinking smooth body fox with dsc from accutune unless someone has a better option.
