I need to identify the make of my control arms, specifically the "flex joints","JJohny joints" etc. so I can rebuild them. I have searched high and low and have been unsuccessful at identifying them to date.
I wish I could just grease them, that would be awesome, unfortunately they are worn out.Those are JJ's on one end and a rubber bushing on the other end.
You can just grease those JJ's with Red Line CV-2 grease and put them back together. The grease only goes on the inside where the ba
"Jonny Joint" was stamped into each one of mine. So easy to Identify. At that point https://www.rockjock4x4.com/search?keywords=jj rebuild kit
It has been 3 years since I messed with these things, I put another set of arms in and moved on to the next project., That said, if memory serves, the polly is worn "front to back" vs side to side so smashing them down only netted a small improvement. Honestly thought I would have it long armed by now, delays ugg. I don't know if putting them in the hydraulic press and giving them an attitude adjustment that way would just squish the hell out of them and reshape the pocket as needed or do something I don't like LOL.
Well, this is a $3 fix for your unknown arms that can't make anything worse. That's better than wasting money on long arms.
I had a set just like that at one time. Rough country arms I rebuilt with synergy bushing and Curry J joints.
I do have a set of rebuild kits in the garage for the smaller JJ joints if you want to double check size.
Looks like you are not too far from me.
Question: What do the JJs give you vs a rubber bushing?
Thanks for the info. I ask because my lower adjustable arms look a lot like the ones in this thread but have 2 piece rubber bushings. I noticed there’s a groove just inside the bushing area that looks like it’s for a retainer / keeper for a JJ. Thought I might be able to replace the rubber bushings with a proper size JJ.
