I have a 97 and my driver's side doesn't tumble forward? Is that common for the 97?
That was the first trail run after completely rebuilding the motor and doing a frame swap back in 2010. I brought it home, replaced the windshield frame and hood, put on corner guards on the rear since putting it back on it's wheels did more damage then the roll over, and put it back on the road. I've been driving and wheeling it since.Andy-WhiteTJ - I'm new here and I sure there is a happy ending to your profile picture...at least I hope so.
So the lever is on the back side of the driver's seat?I've owned a '97, a '98 and an '01. On all 3 the driver side seatback leaned forward using the strap or the lever behind the seat, but would not slide or tilt forward using that. You could slide it only using the bar underneath the front of the seat.
On the passenger side it would lean the seatback forward, slide forward and tilt the entire seat using the lever or strap.
If they made one for the driver side that operated the same way then it's news to me.
Yep, and it makes it lean forward, but not slide or tilt. See pictures belowSo the lever is on the back side of the driver's seat?
I'm not in the Jeep today, but will look when I get home.
Look under the front of the seat towards the console. There should be a lever to press down to the floor that will tumble the seat forward. I usually can feel it without having to look. Sometimes my cable from the seat back tipping forward doesn't actuate the seat's tumble feature. Cable may be stretched.Yep, and it makes it lean forward, but not slide or tilt. See pictures below
View attachment 250249View attachment 250250
Well I'll be...just found that little lever under the front next to the slide bar. Never knew it was there! I learn something new on here every day!Look under the front of the seat towards the console. There should be a lever to press down to the floor that will tumble the seat forward. I usually can feel it without having to look. Sometimes my cable from the seat back tipping forward doesn't actuate the seat's tumble feature. Cable may be stretched.
BTW, those look exactly like my seats.
The fold and tumble lever is located under the seat... driver side toward the front near the trans tunnel.Yep, and it makes it lean forward, but not slide or tilt. See pictures below
There was a post on another forum on how to get the lever on the back to work the lever underneath with the cable and it had the part number on it. Can't seem to find it now.Well I'll be...just found that little lever under the front next to the slide bar. Never knew it was there! I learn something new on here every day!
Lever on the back does not make it slide or tumble, but front does. I'll investigate further later and see if it needs some work. Here's a picture with my finger pushing it down for anyone curious:
