hey guys, looking for a little help... I think the gear change intervals on my auto gearbox are weird, the might not be and im being paranoid but though id double check.
to begin with upon taking off it docent want to change from first to second without a little help. ill only be speeding up slightly but the rpms keep getting higher and higher until I roll of the throttle a little bit to encourage it to change to 2nd. it seems as though the rpms will keep going up regardless how light I am on the throttle.
Isn't much concern I'm used to persuading it by now.
the other thing is that im not sure when my tj should be down shifting. I realise its only a three speed so it struggles a bit but if I do 55 kph (35mph) roughly at 1900+ rpm in second gear it will change down very sudden, while speeding up I make sure I keep it at 1900 or below until it passes 35 mph then I give it a bit more to catch up to the traffic that pulled away from me at the lights haha im fairly sure it a normal down shift interval but thought I might check
thank you guys
thank you guys
