I live at high altitude driving regularly in the mountains and haven't found a reason to do this yet. FWIW.
I've had multiple TJs/LJs with the 42RLE. With the correct gearing, I've never felt a need to do this modification. Generally, the only time I use the OD off switch is on the trail. If one doesn't re gear, I could see it being useful though, to help until you do.
