Just picked up a 1998 Wrangler and I do have slight bump steer, really not that bad. Jeep wanders a bit above 60 on the highway. But nothing major, replaced the sway bar links as the bushings on the old one were completely gone on the bottom. Drag link and track bar seem aligned well even with the drop pitman arm, should I still remove? I also am unsure of the lift. Measuring the springs it seems to be around a 3-4 inch lift.
Wheels are 15x10 33’s. Swapping to 15x8 black steel wheels later this month.
First post, but looooong time user.
