Also, another sendcutsend.com plug. Some $10/ea. crowfeet wrenches for links and jamb nuts cut from 1/2" AR500.
I'd be happy to share cut files
Curious how the AR500 does as a wrench material, does it resist bending way better than mild? Definitely on my cut list for my first SCS order.
Just a suggestion if you ever make more in the future, rotate the 1/2" drive socket about 5°. Just in case you cant fit the breaker bar in the spot you need, you can flip the socket over and it should fit.
Awesome idea. I'd bought these from Motobilt.
https://motobilt.com/collections/newest-products/products/jam-nut-wrench-set-2
But prefer your idea a lot more.
That's not a bad deal for 10 wrenches, per say.. but you might end up paying for a bunch you never will use.
Looks great. And yes it's a lot of work but the results are worth it.
Don't forget to get a spacer for your tank mount.
Started playing around with rear towers. found the "Sweet spot" for them so cut the frame and they're "frenched in". With JK axle's and wheels with 4.5" of backspacing, top of 3" wide 2.0 coilover will rub.
How the hell are guys fitting coilovers in the rear of TJ width axles?
Not speaking from personal experience but if you look at Blaine's builds, he cuts entirely through the rear frame and adds a new section of frame on the inboard side to fit the poly tower through. IIRC the back face of the tower is 1" past the frame. You'll have to hunt for the pics, I don't remember which thread he posted them in.
PS those Fox 1.0's look a little stiff
Is that at ride height? Have you checked your clearance at full articulation? Hard to tell from the pic.
As to running coilovers on TJ width axles? I don’t think I’ve seen anyone do that.
