I just pulled the dash to install a new heater core and evap. When I pulled the dash out a piece went flying. Anyone know where this belongs?
I did the same thing. It’s the door light switch. Yours broke off. You’ll probably find a spring somewhere too. Most likely the drivers side but could be passenger side also. It’s less than $10 on Amazon.
Thank you link!
same happened to me so i switched to the mercedes door plungers
I’m not that smart. I literally just replaced my evaporator and heater core and broke one on the drivers side when removing the dash. Side note….I didn’t pull the steering wheel. No need. Plenty of room to remove the HVAC box by simply using ratchet straps to hold it up and out of the way….but I did break the switch on the drivers side so have one on order.
Yea, changing the heater core and evaporator has been a real pita
Is there a trick to avoid breaking this when pulling the dash?
I've done at least 10, I will pay lots of money to see someone get the HVAC box out in an hour starting from nothing removed assuming we aren't brutalizing everything and just yanking it apart.I had the old HVAC box out in about 1 hr.
